09-11-2023
01:25 PM
09:01 AM
09-12-2023 11:59 AM
Hey Donny,
You never mentioned the type of device you are using, what kind of phone was it? Depending on the model/manufacturer, you may be able to locate where the device was last.
There is also a How-To article on what you should do when your device is lost. I highly recommend this article for your next steps.
10-15-2024 09:44 AM
Good morning, @Adcomm56. Welcome to the Virgin Plus Community, and thanks for your post.
Geolocation is determined by the GPS services built into your phone, and is not something provided or serviced by Virgin Plus. You'll want to look into similar "Find My Phone" services provided by your phone's manufacturer for further assistance. To get you started:
Best wishes.
09-12-2023 11:59 AM
Hey Donny,
10-04-2023
04:06 PM
04:10 PM
lost my phone but not stolen. how can I locate
10-12-2024 06:24 PM - last edited on 10-15-2024 11:51 AM by VirginPlusDRock
Is there a way to locate the position of my own phone?
10-15-2024 09:44 AM
Best wishes.
