Options
06-05-2025 07:57 PM
- I have a question about phone calls via phone vs calls via app, such as Snapchat
- is there a cost difference?
Options
06-07-2025 02:00 AM
very simple, any apps using WiFi network is will be free of charge.
but if you using date mobile and you have a date limit and then after the end of your date limit there will be extra charge fees.
Options
06-07-2025 02:00 AM
