09-06-2021 08:35 PM
So, I have an LG G8 Thinq that is 2 years old. I have always had good service. However, in the past 3 months, I have found that when I am on a call after about 45 - 60 mins the call quality starts to break down. The other party can hear me but I cannot hear the other party. The call breaks up. I can only figure it is something on Virgin's end. Any thoughts?
09-07-2021
09:00 AM
04:26 PM
Hi there! Thanks for bringing this up to our attention. No worries as we're here to help. Regarding this matter, as of August 24, 2021 there is a new update available to resolve this issue. Please ensure you have the latest version of the Google application installed on your device. Please see steps below;
To check the version of the app:
- Go to Settings
- Open Apps and notifications
- Select the Google app.
- Scroll to the bottom and check your application version under Advanced.
- If you are not on version 12.33.16.23 or higher, please update the app to resume phone service.
How to update:
- Open the Google Play store
- Enter “Google Search” in the search field
- Select the Google app by Google LLC
- Select Update
Thank you and we're looking forward to your positive confirmation.
09-07-2021
09:00 AM
04:26 PM
- Go to Settings
How to update:
- Select Update
06-08-2025 07:09 PM - last edited on 06-09-2025 08:47 AM by VirginPlusDRock
When I try to talk on my pixel8a with Virgin services I can hear others fine but 80% of the time they can't hear me. This happens in and outside of my house. Went to an Authorized depot for the phone and they claim that's not the problem. I do notice that mostly only have one bar.
If this issue is poor coverage with Virgin how would I get out of this contract.
06-10-2025 11:18 AM - edited 06-10-2025 11:19 AM
Hey there @stelar ,
As the Community is a peer to peer assistance channel, it would be hard to determine the cause. However, signal strength can be affected by many factors; line of sight to towers, topography, the amount of users connected to the tower and many more.
In order for the Community to best assist, some extra details will be needed;
- Are you only seeing issues with your calls? What about text messaging or data usage?
- Do you have a phone case that may be blocking the receptor opening?
- Do you know of anyone else in the area having similar issues?
- Have you tried to restart your phone and reset the network settings?
- Have you got in touch with our technical support team to open a ticket?
Additionally, we would like to recommend Wi-Fi Calling
as this is going to be the most commonly recommended fix for reception issue if you're in a low network area.
