12-07-2022 04:35 PM - last edited on 01-19-2024 10:29 AM by VirginPlusDRock
For the past month I have been receiving voicemail messages without anyone calling. When this happens, I have not missed any calls. It is like whoever is dialing my number has it to go straight to voicemail. The voicemails are typically blank or sounds like background noises. I did sign up to have my number on the "do not call" list however, this continues to happen.
This is quite annoying as it happens every day and with a 3 voicemail cap, I have to keep checking & deleting them. I'm pretty sure it's a robo call thing but I am not sure how to stop them.
Anybody have an idea on what to do?
03-30-2024 09:35 AM - last edited on 08-26-2024 12:03 PM by VirginPlusDRock
Good morning, @Kevin Eliuk. Welcome to the Virgin Plus Community, and thanks for your post!
As an FYI, we do offer an option for Virgin Plus members to adjust the number of rings before a call will go to voicemail. Could you check out the instructions provided in our thread on changing the number of rings before voicemail picks up and put your theory to the test?
Let us and the rest of the Community know if it makes for any difference. Looking forward to hearing back from you.
03-30-2024 01:36 PM
Thank you Kris,
Thus far, the instructions have seemed to work for my Samsung phone, but the iPhone SE is still going to voicemail on 3 rings after trying to set it to 30 seconds.
We have called into Virgin Mobile support for assistance.
04-01-2024 02:11 PM
Hi there, @Kevin Eliuk.
Just wanted to check in and see if you had had any change in regards to your iPhone, or if you had heard back from Tech Support as of yet.
Let us know if you were still in need of assistance.
04-22-2024 08:38 PM
For the past 6+months, occasional random incoming calls go straight to my VM - these incoming calls do not notify me. There is no notification like my phone ringing, nor are these calls even shown in my Phone log. The callers range from Unknown Callers to occasional callers to my Best Friends. They could call at 5 pm and it rings fine but later on , it goes straight to VM
There us no rhyme or reason as to which caller and when this happens. I did all the general troubleshooting as far as eliminating possible causes- the last step with buying a new SIM Card.
So I installed a brand new SIM Card (Virgin updated my account) on Apr. 18/24 and for the first few days, there were no issues. I got incoming calls fine - multiple calls - no problemo. Unfortunately, I've now heard from 3 friends that it's doing the same thing again.
I can't afford a new phone so I Really hope there is a simple workaround for this issue.
Any help is appreciated, thx.
L
04-26-2024 05:52 PM
I am not getting incoming calls sometimes and the calls directly forwarding to voicemail. And I lost WiFi calling option .
06-11-2024 12:22 PM
I am experiencing this problem and I am not understanding the real causes. People call my number from Canada or from other countries and tell me that my number sounds busy or that they get a message saying the number they are calling is not available at the moment. I have checked all the functionalities of my mobile device and nothing indicates that call forwarding or do not disturb mode is active. This concerns me a lot because I really need to keep this number active for any calls or emergencies, and the problem is that people cannot contact me. I want to clarify that the other services of my plan are working correctly, the internet data service, SMS messaging, but everything related to incoming phone calls to my device is not working. I can make calls, but everyone who tries to contact me gets a busy signal or is told that I am unavailable. I need your help, please. Thank you.
07-10-2024 02:02 PM
This going direct to voicemail happens only when it is Virgin answering a scheduled call. I have attempted changing a number of settings and so far nothing has worked
07-31-2024 07:45 PM
I can make calls, send and receive text messages on my phone but caller gets an "unable to complete call as dialed" message. This is a new prepaid account, brought my own phone.
PS phone is an new "old school dumb" phone so no internet.
09-09-2024 01:52 PM - last edited on 09-09-2024 03:18 PM by VirginPlusDRock
Hello everyone.
Here is my dilemma, I just transfer my landline to cell. Every time i call from Rogers or Bell cell it goes direct to voice mail. I might be missing phone call from my doctor or any other important calls. Some calls go through and some don't.
i have called tech support and they say nothing is wrong, should i change the sim card.
I need to fix this asap.
10-27-2024 12:27 PM
I just transffserd to Virgin last Friday, Oct 25, 2024. Since then, i am in trouble with receiving call and message, the calls directly go to the voicemail, and my phone no action to the calls and can't listen the voicemail. the outgoing call and data is ok. I tried everything i can do and the store helped me changed the sim card , not working. I am so sad, when my phone can back to normal?????????????
- « Previous
- 1
- 2
- Next »
