05-10-2023 11:59 AM
05-11-2023 02:20 PM
Hi there, @Tazzer. Welcome to the Community.
If you click on View All while browsing the Continue Enjoying section, you'll see an option for Edit in the upper right hand side. Once selected, you can remove the shows of your choosing.
Let us know if you have any further questions.
05-11-2023 02:20 PM
05-11-2023 03:36 PM
When I do the above as you suggested on my TV, there is no Edit button. Are these instructions for the Virgin plus tv mobile app?
05-11-2023 05:45 PM
Hey there @Tazzer,
Please try the steps below to delete the 'Continue Enjoying' history, and let the Community know how everything goes.
Go to Settings > Select Clear History
- Patricia
05-11-2023 05:56 PM
Thanks for your reply. I did not want to delete all of the shows in the history, so on the Virgin Plus TV app on my phone, I went the view all in continue enjoying, then chose edit and delete each individual show.
