02-26-2022 02:51 PM - last edited on 01-08-2024 08:19 AM by VirginPlusKris
I am on vacation and want to know if i am within wifi, will i b charged roaming charges?
- Labels:
Samsung
03-01-2022
02:07 PM
07:58 AM
VirginPlusAlexa
Hey there @Rockstar194,
Welcome to the Community and that's a great question.
Roaming charges would only occur if your device connects to the local network. For more information you can visit our Roam Sweet Roam FAQ's support article.
Certain types of usage will not result in the daily charge, including: making a call to Virgin Plus Care, receiving texts, or using non-chargeable data.
We hope that you're having a pleasant time on your vacation.☺
12-24-2024
07:14 PM
09:48 AM
VirginPlusAnton
03-01-2022
02:07 PM
07:58 AM
VirginPlusAlexa
08-15-2023
09:51 PM
11:49 AM
VirginPlusAlexa
I recently got charged a big amount for roaming even though I have not used data and had my phone on airplane mode most of the time. Wanted to ask the community, which ones of the following do you get roaming charges for?
1. Using data
2. Making a phone call
3. Sending a text
4. Receiving a phone call
5. Receiving a text
10-31-2023 05:24 PM
We will be travelling to the US from Canada. Since we will have other means for making/receiving telephone call we want to prevent receiving any charges due to incoming calls on our Virgin Plus account. We can turn off/block incoming calls at the phone level (android), but will doing this prevent charges as well?
If not, how can we tell Virgin not to send any incoming calls?
Can we access the phone's voicemail (via another device) without incurring charges?
Thanks
10-31-2023
08:10 PM
10:02 AM
VirginPlusAnton
Hi @AOCGenie
turn on your airplane mode .. to you not getting any service.
to access your voicemail
Dial your 10-digit phone number from another line and Press the # key to interrupt the voicemail message centre and Enter your password.
if you need Roaming and Travel review Add-ons option click Here and also Here .
10-31-2023 11:55 PM
Thanks for this information. However, we may want to use wifi from time to time so turning on airplane mode would not allow that. I found a reference to an 'auto reject mode' (https://www.techguide.com.au/faq/android/how-to-block-incoming-calls-on-android/) which it says will reject all incoming numbers. But I don't know if that will prevent a charge from being made on the phone bill.
Does anyone know it it would?
Thanks
11-01-2023 12:20 AM
Hi @AOCGenie
when turn on airplane mode .. is will be no any service from provider.
and turn on your WiFi is will be on all time and no issue will be working fine the WiFi.
i think is will be charge for the auto reject mode because your line will be in service.
11-01-2023 11:58 AM
In my first test, turning on airplane mode did turn off wifi, but when I tried it again I was able to turn wifi back on while leaving airplane mode on. So your solution was correct. Thank you.
11-01-2023 04:04 PM
Hi @AOCGenie
your welcome, my pleasure, enjoy your trip.
12-13-2023
02:04 PM
08:23 AM
VirginPlusAlexa
When you are roaming out of Canada do you have to pay the roaming fee even when you are not using data?
12-14-2023
08:31 PM
10:03 AM
VirginPlusAnton
12-24-2024 10:56 AM
Does anyone know if the Roam sweet Roam will charge my account if the Airplane mode is off while the data plan is disabled while I travel aboard?
12-24-2024
07:14 PM
09:48 AM
VirginPlusAnton
05-30-2026
08:47 PM
08:11 AM
VirginPlusAnton
I went to China last month, and turned off the data roaming of my phone (iPhone 12), but in the end, still have 6 events of data usages international. I don't know how this happen, is it possible Virgin plus charging me incorrectly? Anyone has similar experience, pleas feel free to input, Thanks!
