How does Incoming vs. Outgoing calls on Travel Passes work?
Boo
Will a person using a Portuguese number be charged long distance charges if I am using the Global 365 day travel pass on my Canadian number?
Hey there @Boo ,
The limited-time Global Travel Pass offer, offers unlimited talk & text and use the data in your plan in the U.S. and all 200+ Roam Sweet Roam international destinations. It includes unlimited Talk and Text to Canada and within your destination and uses data from your existing rate plan.
For details on other travel passes, you can check out the same link above, scrolling down to "What desitination are you traveling to?" and clicking Learn more on your Travel Pass of choice.
If we understood your question correctly, in the instance that the person with a Portuguese number calls you, they will be subject to their plan coverage.
Let the community know if you have more questions.
2 REPLIES 2
Hey there @Boo ,
I will be travelling to the Dominican Republic and would like to purchase the International 14 day pass. I just want to confirm that the pass includes unlimited calls to and from Canada ? Without using my current data?  I will  have wifi and the place I will be staying but am more concerned with calls as I have someone staying with my elderly mother and need to able to receive calls/texts when not on wifi. I often have my phone on airplane mode and just use wifi when travelling internationally. Thanks in advance
