Blocking calls to USA along with blocking Global Calls
PRS
Dear Sir or Madam
Please enable blocking of chargeable long distance calls including USA and Global Calls from the User's cell phones.  It will help in avoiding accidental calls and accidental return calls without knowing whether the call is in Canada or the USA.
Thanks & Regards
PRS
Hi there, @PRS.
We have sent you a Private Message. Please check your inbox next your Profile avatar.
Unsure of where to find your inbox? Check out this link.
3 REPLIES 3
Hi there, @PRS.
Dear Sir or Madam
Although my long distance calls and global calls are blocked, unfortunately - the calls are still going to the USA!!!!  Is there any way the calls to USA could be blocked permanently!
Please enable blocking of chargeable long-distance calls including USA and Global Calls from the User's cell phones.  It will help in avoiding accidental calls and accidental return calls without knowing whether the call is in Canada or the USA.
Your computer could help in identifying and blocking the calls to the USA!!  It will be of very much help to many of your customers!
Thanks & Regards
PRS
VDG
Hi,
Until recently I could not make any international calls. It just got blocked but now international calls are going through !!!
I got charged at a rate of CAD 2.50 per minute!!!! Fortunately it was a very short call but there was no indication that this was an international call. i could easily have run hundreds or even thousands of dollars in a month.
Please show me how to block international calls. I am in Quebec, Canada.
Thanks.
