- Article History
- Mark as Read
- Printer Friendly Page
02-03-2026 03:19 PM - edited 02-04-2026 04:03 PM
How to Reset Your Voicemail PIN
If you've forgotten your voicemail PIN, you can easily reset it in minutes. Follow the steps below using either the My Account web portal or the My Account app.
Using the My Account Web Portal
- Log in to the Virgin Plus My Account web portal.
- Navigate to the "My plan & add-ons" section.
- Find the "Voicemail PIN" option and select "Reset PIN".
- Check your email for a temporary PIN. Use it to access your voicemail, where you will be prompted to create a new and permanent PIN.
Using the My Account App
- Open the Virgin Plus My Account app and select your phone number.
- Tap on "Manage my device", then "Feature settings".
- Select the "Voicemail PIN" option.
- Tap "Reset PIN". You will receive a temporary PIN in your email to access your voicemail and set a new and permanent PIN.
Frequently Asked Questions (FAQ)
What should I do if I don't receive the temporary PIN?
First, check your junk or spam folder. If you still can't find it after a few minutes, try the reset process again. If the issue persists, make a Post in the Virgin Plus Community and we'll help you out.
What are the requirements for a new PIN?
Your new PIN should be easy for you to remember but difficult for others to guess. Avoid using simple sequences like "1234" or personal information like your birth year.
