02-24-2022 05:26 PM
Hi.
i recently moved to virgin mobile. When i was with Rogers, i used to get voicemail transcripts under voicemail. I am not sure if virgin have that feature. I don't see any transcripts since then.
02-28-2022 03:33 PM - last edited on 05-03-2025 01:54 PM by VirginPlusKris
Hey there @AAZAV,
Welcome to the Virgin Plus Community and thanks for your post.
You're correct, Voicemail to Text or Visual Voicemail are not included in our plans, however with a small Voicemail upgrade you will have the ability to add the service on your account (the monthly charges will depend on the package you select).
We also have a new complimentary Voicemail via MMS
option that can be activated on the standard voicemail at no extra cost and will send you your voicemails as audio files via MMS (Multimedia Messaging Service).
Let us know if you have any further questions. Best wishes.
Hey there @AAZAV,
05-03-2025 01:41 PM - last edited on 05-03-2025 01:54 PM by VirginPlusKris
Is there a Voicemail-To-Text add-on that was automatically added on? I received a message one time but can’t recall…? 🤷🏽♀️ thanks
