help long distance usage
Ashtrid-26
What if you have an unlimited long distance and how long is the distance for me to use, so I wouldn’t be charge for using it. Would I be able to call and text someone from the other side of the world?
2 ACCEPTED SOLUTIONS
Hey there @Ashtrid-26 ,
That's a tricky question since the community is a peer to peer assistance channel and we do not have access to your account details. However, if you check your plan details on My AccountOpens in a new tab or window, it will show the parts of your mobile plan including any long distance package you subscribed to.
To learn more about long distance, check out long distance add-onsOpens in a new tab or window from Virginplus.ca.​
Let the community know if you have more questions.
1EYE
Regular Contributor
You can find the rates here
https://www.virginplus.ca/en/support/canada-long-distance-rates.html
I am a former Virgin Plus employee and a customer. My views on the Community Forum are my own and may not be the views of Virgin Plus or any of its affiliates.
5 REPLIES 5
Cost of long distance per minute calling to USA
1EYE
Regular Contributor
The plan I have is:
Loy+ BYOP $36 - 70GB
It states unlimited texting etc, just wondering before I get a $200 bill for forgetting to end a call.
Want to know if I can call U.S. from Canada at no cost on my virgin plus plan?
