Voicemail does not create after hanging up
f3a46
When someone tries to leave a voicemail with me, they cannot do it unless they wait a long time after recording their message in order to press a number to confirm to send. When I was at a different service provider, hanging up the call after recording the message will automatically leave me the voicemail.
Is there a way for that?
Hey there @f3a46 ,
That's definitely odd, as when someone is done leaving you their message, a simple hang up will automatically save the recording in your inbox.
We will be happy to have a closer look and reset your voicemail for you and troubleshoot further if needed. We've sent you a private message with the details needed to get started.
Thanks.
Hey there @f3a46 ,
Thanks.
