phone stuck in airplane mode.
missbritt
hello,
I have done everything from safe mode, network reset, cache clear, and even factory reset the device and I cannot get this phone out of airplane mode. someone please help!
Hi there, @missbritt. Welcome to the Virgin Plus Community.
To be clear, are you specifically stuck in airplane mode? Or is it a loss of signal / reading as SOS only? Airplane mode can only be set at the device level and we would not have control over that specifically.
If it is specifically airplane mode, please take a look at the following support articles for Android and iOS.
Android : Keep your Android’s wireless connections on in Airplane modeOpens in a new tab or window
iOS : Use Airplane Mode on your iPhone, iPad, iPod touch, and Apple WatchOpens in a new tab or window
