How can I choose Redmi device by Xiaomi?
Xiaomiuser1991
Hey there.
I would like to know how can I choose Redmi smartphone as my device?
Hey there @Xiaomiuser1991,
Welcome to the Community.
In order to review the device that are being offered by Virgin Plus, click here.
You can also bring in your own device if it is unlocked and compatible with our network.
You can verify if your device is compatible with us here.
6 REPLIES 6
Would a Palm Phone PVG 100 work on the Virgin network?
I have a Bell ZTE MF288 Data Port at end of contract.  Wondering if I can get a Plan/SIM from Virgin at a better price point than I'm getting from Bell?
I have a Bell ZTE MF288 Data Port at end of contract.  Wondering if I can get a Plan/SIM from Virgin at a better price point than I'm getting from Bell? Device uses a standard SIM card and has both voice and text capabilities.  Wondering if a standard Mobility plan would work.  Would need approximately 30 GB data.
Does the Samsung Galaxy A14 5G [unlocked] have any compatibility issues with the Virgin network?
I would like to buy a new phone and i need to know if it will work with Virgin.
It is a Motorola Moto G54 Dual-SIM 256GB ROM + 8GB RAM 5G (Only GSM | No CDMA) Factory Unlocked Smartphone - International Version
