Virgin mobile error code 2
Dawson
What does this error code mean? Got it while trying to send a text. How do I fix it?
2 ACCEPTED SOLUTIONS
Hey there @Dawson
The error 002 means that the phone number format itself is correct but the message could not be delivered due to an unavailable network connection between the carrier and the handset. Possible causes: the handset was switched off or the handset was out of coverage area.
Normally a simple phone restart should fix the error.
Give that a try and let u know the results.
Hey @Evelyn,
Welcome to the Virgin Plus Community and thanks for your post 🙂
We included a few pages below that we think will be helpful in your case.
Keep the Community updated, and let us know if you're still getting the error after trying the troubleshooting tips and tricks.
- Patricia
3 REPLIES 3
Hey there @Dawson
Hi Virgin
I've been having the same issues when trying to send a text. I have lots of data, have tried restarting my phone and switching between airplane mode. Are there any other solutions to this problem? I have a Samsung FE 20.
Hey @Evelyn,
- Patricia
