Unable to send picture messages
Rickdill
My pixel 8 won't send pictures to iPhones. Not sure why any help
3 ACCEPTED SOLUTIONS
RedRose
Regular Contributor
Hi @Rickdill
You can go to Settings > Messages to check if the MMS Messaging is toggled on. If not, tap the switch to turn it on. If it's on, you can turn the feature off and on again to refresh the MMS function.
  • Try Reset Network Settings
  • Verify Correct APN Settings
  • Check Software Update up to date
  • Check Update Your Message App
  • Clear the message app cache and clear data
  • If using advance messaging, try turning the feature off in your settings
Reboot both device
RedRose
Regular Contributor
Hi @Rickdill
How to Reset Network Click  Here
For iOS, tap Settings > General > Transfer or Reset > Reset > Reset Network Settings.
Verify Correct APN Settings on pixel 8, try these steps:
1.Navigate to the Settings menu.
2.Select Mobile Network/Connection Settings.
3.Select Access Point Names.
4.Add a New APN setting.
5.Fill in the following settings:
  • Name: Virgin Plus
  • APN: pda.bell.ca
  • Proxy: web.wireless.bell.ca
  • Port: 80
  • Username:
  • Password:
  • Server:
  • MMSC: http://mms.bell.ca/mms/wapenc
  • MMS proxy: web.wireless.bell.ca
  • MMS port: 80
  • MMS protocol: WAP 2.0
  • MCC: 302
  • MNC: 610
  • APN type: blank
6.Press Menu and Save
turn on your data service to allowed your MMS going through,
Reboot device.
RedRose
Regular Contributor
Hi @Rickdill
do you Clear the message app cache and clear data
turn on your data service provide not WiFi and ask your friend has the iphone is the data service is on !
if your issue with only one number can't send photos delete the number from your device and re-add with +1 in front of area code.
if your issue with all friends can't send photos then try your SIM card in other device, if is working from another device then try to Backup your staf and do factory reset.
but if your SIM card is not working from another device and your data service provide not WiFi just to you know, is working fine then contact to support team to open a ticket to fix it for you.
For more tips and tricks; Check out Troubleshooting text, picture and video messagesOpens in a new tab or window
10 REPLIES 10
RedRose
Regular Contributor
Hi @Rickdill
Reboot both device
Sorry but Not sure what you mean by reset network settings verify correct APN
RedRose
Regular Contributor
Hi @Rickdill
  • Name: Virgin Plus
  • APN: pda.bell.ca
  • Port: 80
  • Username:
  • Password:
  • Server:
  • MMS port: 80
  • MCC: 302
  • MNC: 610
  • APN type: blank
Reboot device.
Rickdill
Thanks but that didn't work,but again thanks
RedRose
Regular Contributor
Hi @Rickdill
Rickdill
Thanks I got it working with what you told me to do, I wasn't sure about the APN but I figured it out. Thank you
I cannot send photos from my Samsung phone using Samsung Messages to another person on Virgin. I can send the photo to a non Virgin user, and can send it in a group chat that consists of both Virgin and not virgin customers.
Why can't I send to Virgin customers?
Tinkerbelle
It's not just the Google Pixel phone that will not send images to an iPhone. I have been having that issue now for weeks with a Samsung S53! The instructions that I have found online to help with this issue do not work.
I have a (Xaiomi) Redmi Note 12 turbo, I could send pic messages when I was with Tellus but not now that I switched to Virgin. I've tried just about everything..
I bought a global version Xiaomi Ultra 14 phone recently and have an issue with sending mms messages.  I cannot send or receive any messages with pictures or GIFs.  When I got a voice message, Virgin Mobile usually sends me a text message with the voice mail message in an attachment and I cannot receive the notification from Virgin Mobile too.  It has become a problem.  Can anyone has similar experience and help?  Thanks.
