Forwarding text messages
Johnnotjean
Ok but how do you forward an SMS message to another number?
Hi there, @Johnnotjean. Welcome to the Virgin Plus Community.
If you're an iOS user, check out this Support article from Apple on How to forward SMS/MMS text messages from your iPhoneOpens in a new tab or window
For Android, you can use these following instructions:
  1. Open the Messages app.
  2. Tap and hold on to the exact message you want to resend.
  3. Once the message is selected, tap on the three-dot icon at the top right.
  4. Select Forward.
  5. Tap on a name in the presented list, and you can forward the message to them.
  6. If you want to forward the message to a new number or another contact, tap on New Message. Select or search for a contact.
  7. When ready tap the Send button.
Let us know if you have any further questions.
  4. Select Forward.
