Options
11-13-2023 09:45 PM - last edited on 11-14-2023 08:55 AM by VirginPlusDRock
Can I totally block a phone so it cannot use wifi? I need this for my son, ONLY talk and text
Options
11-15-2023 07:31 PM
Hi @Norma
Blocking Internet Access are specifically for Android devices.
- Open Settings
- Select More networks
- Select Mobile networks
- Select Access Point names
- Select you APN
- Select Options
- In the popup window, select APN and type “xyz”
- In the top-right corner, select Options and then Save
for iphone Here
Options
11-15-2023 07:31 PM
Hi @Norma
- Open Settings
- Select you APN
- Select Options
for iphone Here
