APN settings
03-11-2022 07:18 PM
Why aren’t there any options to change APN settings in “cellular network” with Virgin Plus? My Virgin Plus service is set up with an eSIM. This option is available with Telus with a physical SIM card.
03-14-2022 03:03 PM
Hey there @en2cas,
In order for the Community to best assist a few more details will be needed.
- What's the make and model of your phone?
- Are you having issues activating the eSIM or using any specific service on your phone?
03-15-2022 12:43 PM
03-16-2022 03:11 PM
When using a physical Virgin Plus SIM card, you will have access to the APN settings on your phone.
03-17-2022 08:39 PM
Is it possible to switch back from eSIM to my deactivated Virgin SIM card? Also, would 5G be available using an eSIM?
03-21-2022 02:59 PM
If it's been more than 90 days since you've changed from your physical SIM to the eSIM, then a New SIM Card will need to be purchased.
